11-25-2015 10:22 AM
LabWindows 2013 SP1 has suddenly stopped functioning on my PC. Any time I try to open a file, either by clicking Browse on the welcome page, clicking the File Open icon, or selecting File - Open or File - Save As from the main menu, I get a popup Windows message that says "LabWindows/CVI 2013 has stopped working".
Clicking on "Show problem details" shows this:
Problem signature:
Problem Event Name: BEX
Application Name: cvi.exe
Application Version: 13.0.1.201
Application Timestamp: 52d6eeab
Fault Module Name: CVI.dll
Fault Module Version: 13.0.1.201
Fault Module Timestamp: 52d6eea1
Exception Offset: 00a4ecd0
Exception Code: c0000409
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 417a
Additional Information 2: 417afcd3ce602885d582521ac0f0405e
Additional Information 3: 39bb
Additional Information 4: 39bb24ea28d79f3c45538f96792cdc59
These values are always the same.
I am running Windows 7 Professional, SP 1.
Solved! Go to Solution.
11-30-2015 01:55 PM
Were there any noticeable changes to your PC between the time CVI was functional and non-functional? Also, does this only happen when opening a particular project, or does this happen with any project?
If this problem is specific to CVI and not a particular project, you should try a Force Reinstall to overwrite any potentially corrupted files.
11-30-2015 02:34 PM
It happens with any project.
I haven't installed any new programs on my PC, but our I.T. department periodically deploys patches onto our machines, so something could have changed that I'm not aware of.
12-01-2015 07:30 AM
I just installed CVI 2015 and I am still having the same problem.
12-01-2015 07:46 AM
Here is the crash information from CVI 2015:
Problem signature:
Application Version: 15.0.0.408
Application Timestamp: 5583c33f
Fault Module Version: 15.0.0.408
Fault Module Timestamp: 5583c332
Exception Offset: 00a6e310
Locale ID: 1033
Additional Information 3: 1847
Additional Information 4: 1847e41850adf6e95315ac08efe0215c
12-01-2015 12:40 PM
If you just did a normal install of CVI 2015, it might still be worth trying a force reinstall. It's possible that there is a corrupted CVI 2013 file somewhere.
Taking information from a similar post here, it seems like this issue could be specific to your Windows configuration.
12-01-2015 07:00 PM
12-03-2015 07:46 AM - edited 12-03-2015 07:46 AM
Here it is.
01-14-2016 03:39 PM - edited 01-14-2016 03:49 PM
I uninstalled all LabWindows versions and all other National Instruments software from my PC, rebooted, and reinstalled the most recent version (2015) and the 8.1 SDK. This appears to have fixed the problem.
