01-13-2013 06:51 PM
I encountered 'CRT not initialized error' after installing MS Office 2010. I think that with previous version of CVI there were no problems. But, with Labwindows/CVI 2012 error has outbroken. The details are as follows.
- OS : windows 7 Enterprise (32bit)
- Labwindows/CVI (v12.0.0 (422))
- MS Office 2010 (word, powerpoint, excel)
#1. clean install windows 7 (32 bit)
#2. install Labwindows/CVI v12.0.0 and device drivers (DAQ, Motion)
#3. compile and run attached test program : SUCCESS
#4. online update windows 7 (service pack, explorer 9, and etc)
#5. compile and run attached test program : SUCCESS
#6. install MS Office 2010
#7. compile and run attached test program : 'CRT error'
#8. uninstall MS Office 2010
#9. compile and run attached test program : SUCCESS
I think there are some conflicts between office 2010 and labwindows v12.0.0. How can I solve this problem?
Thank you in advance.
01-13-2013 08:30 PM
More specifically, I decided that some parts of MS Office files and features of NI's motion library conflicts. Because in the attacted sample program, if I exclude NI-Motion functions then the program excutes nicely. But if I include NI-Motion fucntion, for example flex_select_signal, then the 'CRT not initialized' error occurs.
To solve this problem I tried step by step installation check for MS Office 2010. During each step I included more optional features in MS Office and after each installation I compiled and executed my sample program. At finally, I found that the addtional part of MS Office 2010, if I install Office Sharing Function>Microsoft IME(Korean), then the 'CRT not initialized' error occurs.
Temporarly, I solved the problem with NOT installing 'Office Sharing Function>Microsoft IME(Korean)' optional feature in the MS Office 2010.
Could you tell me why this problem occur?
01-15-2013 07:01 PM
Does repairing the installation of NI-Motion after installing MS Office resolve the issue?
What version of NI-Motion do you have installed on your system? I would like to try to reproduce this.
01-15-2013 11:04 PM
NI motion : v8.4
And the re-installation of NI-motion cannot resolve the problem.
I found that the only solution is the uninstallation of 'Office Sharing Function>Microsoft IME(Korean)' in MS Office 2010 optional feature.
Thank you.
