10-07-2014 08:29 AM - edited 10-07-2014 08:32 AM
I am new to LabWindows and I have to fix a bug in a software, which is written by someone who left the company. But I can not even compile very properly.
There are some DLLs, written in C# and built in Visual Studio 2013. If I run the program it gives an error :
NON-FATAL RUN-TIME ERROR: "c:\...\udp.net\UdpDotNetCommunicator.c", line 47840, col 5, thread id 0x00001D38, function id 2: Function CDotNetInvokeGenericMember: (return value == -6571 [0xffffe655]). The target invoked by the LabWindows/CVI .NET Library threw an exception.
According to .NET Library Error Codes (http://zone.ni.com/reference/en-XX/help/370051M-01/cvi/libref/cvidotnet_library_error/ it is The target invoked by the LabWindows/CVI .NET Library threw an exception.
But I have really no idea.
And the source code in UdpDotNetCommunicator.c line 47840 is so:
__errChk(CDotNetInvokeGenericMember( __assemblyHandle, "ControllerBoard.Communication.UdpCommunicator", __instance, CDOTNET_CALL_METHOD, "ReadRegister", 0, 0, 4, __parameterTypeNames, __parameterTypes, __parameters, &__returnValueTypeId, &__returnValue__, __exception));
What can I do? It gives this error 20 times and continues to run if I click "Continue".
Thanks.
10-10-2014 07:38 AM
this error can happen when the library was not correctly registered (that it is not found in the GAC). Have you already seen the following thread ? http://forums.ni.com/t5/LabWindows-CVI/What-is-the-labwindows-cvi-equivalent-to-the-net-constructor/...
I hope this helps.
Aurelie
