11-26-2010 05:40 AM
12-02-2010 06:45 AM
Hello Norbert,
I have some questions for you:
1. Which CANON EOS camera do you use?
2. Support National Instruments this camera?
http://sine.ni.com/apps/utf8/nipc.specs?action=search&asid=1102
http://digital.ni.com/public.nsf/allkb/4331B4AA3AE95233862574C200539A2F?OpenDocument
3. Do you use a National Instruments Vision Software?
http://www.ni.com/vision/software/
4. How do you connect your CANON EOS camera to you PC?
http://joule.ni.com/nidu/cds/view/p/id/415/lang/en
http://zone.ni.com/devzone/cda/epd/p/id/3938
http://zone.ni.com/devzone/cda/epd/p/id/1212
http://zone.ni.com/devzone/cda/epd/p/id/897
You can find more examples on this page:
Best Regards,
Phanuel
12-02-2010 09:10 AM
12-14-2010 09:22 AM - edited 12-14-2010 09:24 AM
Hi Norbert,
http://decibel.ni.com/content/docs/DOC-4155
Do you use the "Picture Control"?
http://zone.ni.com/reference/en-XX/help/370051P-01/cvi/uiref/cvipicture_control_overview/
http://zone.ni.com/devzone/cda/epd/p/id/4889
You can also use the canvas control.
http://zone.ni.com/devzone/cda/epd/p/id/3475
http://zone.ni.com/devzone/cda/epd/p/id/877
http://zone.ni.com/devzone/cda/tut/p/id/8503
Best Regards,
Phanuel
12-15-2010 12:13 PM
If you just want to display the image, look into a library on the NI Device Driver Reference CD called NI-IMAQ.
There is a very fast image write routine for a canvas control called imgPlot.
12-16-2010 02:40 AM
03-24-2011 04:43 PM
found this thread as I'm also going through this in these very days. This is rather a Canon EDSDK question. Anyway, if still relevant, the answer, which is undocumented by Canon, but apparently known to developers, is that the evf buffer gest filled with a jpeg stream, which you have to decode. There is no VI in labview doing this in memory (I don't know about labwindows), the detour would be either save the stream to a file and reload it (I hate), using some contributed ad hoc function (e.g. http://decibel.ni.com/content/docs/DOC-13513). But the real answer is that the function EdsGetImage can transform jpeg data into an RGB stream, which with further gymnastics can be casted into an IMAQ image.
For a labview implementation: http://groups.yahoo.com/group/CanonSDK/attachments/folder/446301336/item/1078603953/view?picmode=ori...
In general, www.canonsdk.com and http://groups.yahoo.com/group/CanonSDK/ are valuable resources here.
HTH, Enrico
01-07-2014 12:00 PM
I'm thinking about trying this with a Canon EOS. Did anybody get this to work?
01-07-2014 12:29 PM - edited 01-07-2014 12:32 PM
Of course (in Labview, not Labwindows). http://groups.yahoo.com/neo/groups/CanonSDK/conversations/topics/1626 , http://groups.yahoo.com/neo/groups/CanonSDK/conversations/messages/1716 . LV2010, SDK 2.9, certainly not 2.10 and no intention to check any other version.
01-08-2014 01:53 AM
Hi Jeff,
yes i got it to work. Actually we use different models of Canon EOS and the Canon EOS SDK 2.130.
Greetings Norbert
