I upgraded from LabWindows/CVI 5.5.1 to 7.0 and accunter some problems with LW/CVI 7.0 when I want to change some panel attributes on my .uir file, as Enabling/Disabling "Scale Contents On Resize", those changes are not taken into account. It is really a problem!
(What is also noticed is that the "Other Attributes"-Button and the related "Ok"-Button have to pressed two times before reacting).
Thank you in advance for the issues you can give me to fix this problem with LW/CVI 7.0
