Hello Mr. Saller,
I found two more bugs in the UI to Code Converter.
1) When converting a panel to code, there are some variables declared which aren't always used in the code (Ex: int hMenubar, char *dataPtr). When compiling the file, a warning is generated that the variable isn't used (I know that I can turn this warning off but it is useful).
2) When converting to a c-File that is named for example "MyFile.uir.c" or "MyFile-1.c" with corresponding header files, compiling errors occur because of the preprocessor instruction:
#ifndef _MYFILE.UIR_INCLUDED
#define _MYFILE.UIR_INCLUDED
or
#ifndef _MYFILE-1_INCLUDED
#define _MYFILE-1_INCLUDED
The problem is because of the "." or the "-" in the Filename.
