10-22-2014 04:40 AM
Dear all,
I am using Labwindows/CVI 2013 on windows 8.1, and I have a strange behavior on breakpoints. Indeed, my program is not stopping on some breakpoints which I have set.
Randomly, the breakpoints are respected, which means that the program stops correctly on these breakpoints. Randomnly also, the breakpoints are not respected, which means that the program do not stop on the setted breakpoints, event that the program runs the instructions where the breakpoints are set.
I use the debug mode, and the instructions were the breakpoints are set are not comments, they are instructions.
I do not have this behavior when I run cvi 2012, under w 7. I do not know if the issue come from w8.1 or cvi2013, or...,
I would like that this issue wil be fixed.
Thank you for any help.
Cheers,
10-23-2014 10:42 AM
Hi hapiest,
Thank you for posting on this thread.
Can you share a simplified code that reproduces the behaviour and that I could run on my computer without any hardware and the .cws file ?
Also :
- What version of CVI are you using (SP ?)
- Does the berakpoints that are ignored still appread in the breakpoint listing box ?
- If you creates a project from scratch, does it reproduces the issue ?
Best Regards,
Isabelle G.
National Instruments France
Été de LabVIEW 2014
12 présentations en ligne, du 30 juin au 18 juillet
