Hey Nicolas,
I am sorry for my last post; it seems that I was mistaken. All you
need to do is re-run your installation of NI-DAQ by going to
Add/Remove programs, select National Instruments Software, then
highlight NI-DAQ Traditional and select Change. When the installer
opens back up you will see that the support has changed for CVI to
include Borland Support. Any time you change between Borland and MSVC
support you will need to re-run the installer so the proper files can
be installed on your computer.
Sorry about the confusion.
Joshua P.
Application Engineering
