Greeting,
While what the above poster said is true, I don't that this is the problem that you are having. This problem is likely a known issue with CVI 6.0 on certain German operating system configurations.
The German distribution kit will run properly on a German operating system if the locale is set to German-German. But if you run on a different sub-local (such as German-Switzerland or German-Austria), you will get this "transform error" at install time.
You have several options to workaround this issue:
- upgrade to CVI 7.0, as this was fixed in this release
- set the locale of the system to German-German before you install, then set it back when you're done
- rename the file named templateDE.msi in your the CVI\redist folder, and copy in
the one attached to this post (the only difference in this file is that the ProductLanguage property and Languages summary info has been changed from sub-local specific to generic German). Then rebuild you distribution kit with the new template file in place, and it should work properly.
- WesW / NI
