01-14-2013 08:42 AM
I've been developing two CVI applications (call them App_1 and App_2, for example), and I've been looking for the best option to synchronize them. I mean that App_1 must know if App_2 is running or not, and which operation is performing in every moment.
At the beginning I thought to a network variable (created when App_2 starts and deleted when it stops), but this is not an option because if App_2 crashes the network variable is not deleted, but it exists with the last value. And so App_1 would think that App_2 is running...
Any suggestion on a better way?
01-14-2013 09:17 AM
Since you are already on the way to Network Variable, you could benefit from timestamping the variable you are already using. Refer to NVQuality example project for an example of using timestamping of a NV. This could probably address most of your problems, provided the writer continously update status variable even if no change has occurred. Alternatively, you can add a supplementary variable to use as a whatchdog, i.e. the writer continuously writes some different value and the reader checks it has changed over time.
01-15-2013 12:53 AM
Thanks Roberto
what you suggested is more or less the same solution I thought to.
And since an expert like you suggests this approach I think this is definitively the best option
