04-15-2011 04:03 AM
Hello !
Thank you for your help.
There may be my mistake. I will solve the problem as soon as possible.
Thank you again for your support and help.
Best regards.
xiepei.
07-23-2013 05:51 PM - edited 07-23-2013 06:15 PM
(Sorry for duplication of the message. I posted it as new message but I couold not remove the old one)
I am trying to use the Modbus Test CVI code from RobertoBozzolo through a loopback RS232/RS485. However, I am facing CRC error almost every time for any data (doesn't matter write or read).
Unexpectedly some times when I am playing with the numbers and by clicking "write to slave" I get an answer from the port which I belive happens accidently (since using the same number again I receive CRC error).
I have attached the sample answer I got. I think even there is a problem with the answer since function code does not mach.
Could anybody help me on that?
07-23-2013 11:44 PM
(Answered here)
05-18-2015 12:25 PM
I am getting the CRC error whether its read or write and writes work sometines. Is there any way to solve it
05-18-2015 12:25 PM
Did you solve this issue?
05-18-2015 12:27 PM
did you solve the issue?
05-18-2015 04:17 PM
How you detect CRC errors?
Have you tried dumping messages and checking the CRC?
And have you tried checking the calculated CRC on write messsage?
05-19-2015 11:30 AM
Thanks for your reply. it was giving error 532, CRC error.
I figured it out. It was something wrong with the slave unit I was working.
05-19-2015 04:04 PM
I am facing another issue. I am able to read from the device, but i cannot write anything to the device. It gives error 99. I/O operation timed out.
Is there any way to solve this.
I can write to my device when i use another modbus app which i got form internet.
Is there anything specific to the Modbus testing program which i should take care of, when writing?
05-20-2015 12:59 AM
Which instruction is giving you this error? Can you post the relevant part of your code?
Since you say you can "read", this means you can write a query to the device and get a response from it, so you are already sending messages to your device without errors; given this, it seems possible that the problem is in how your write message is built and sent.
