LabWindows/CVI
AutoCorrelate not found in DLL
I keep getting the following runtime error when I try to use the AutoCorrelate Function in Labwindws 2012.
Function AutoCorrelate: (return value == -5094 [0xffffec1a]). The function was not found in the analysis library DLL.
I have included advanlys.h at the top of my function and added the Advanced Analysis LFP to my CVI Customized Libraries.  I am tring to use example code I copied and pasted from the Online Help documentation.   I can't seem to locate the corresponding advanlys.dll that the advanlys.h wants to reference.
Example code below:
#include "advanlys.h"
double x[256], rxx[512];
int n; n = 256;
Uniform (n, 17, x);
AutoCorrelate (x, n, ALGORITHM_CORCOR_NO_NORMALIZATION, rxx);
(3,471 Views)
Which version of CVI are you using? As far as I can remember Advanced Analysis library is not shipped with base version but only in full one.
Additionally, you shouldn't have to manually add the library .LFP to customized libraries list: there should be a checkbox in the upper part of Customise Library Menu window to add/remove Analysis library from your IDE.
(3,466 Views)
I have CVI 2012 Full Developement System.
Analysis Library was automatically checked off in CVI but if I query the definition of AutoCorrelate (Ctrl-I) in the CVI editor, it brings up advanlys.h not analysis.h.   I assumed I needed to add advanlys.lfp to CVI manually.
(3,462 Views)
No need to add advanlys... analysis.h does just this:
#if !defined(_CVI_) || defined(_CVI_FDS_)
   #include <advanlys.h>
#else
   #include <reganlys.h>
#endif
(3,459 Views)
Wolfgang,
That makes sense.   I removed all references to advanlys but it's still complaining that it can't find AutoCorrelate in the analysis library DLL.  I have CVI 8.5.1 FDS on the same machine and I know that AutoCorrelate wasn't part of the Advanced Analysis Library at that time.  Could it be that CVI 2012 is somehow looking at the 8.5.1 DLL?   Is there a way to override this in CVI?   (To force which DLL it uses)
(3,456 Views)
You can check your include path e.g. by opening your *.cws file in a text editor (WordPad...); in my case it says:
CVI Dir = "/c/program files (x86)/national instruments/cvi2012"
(3,452 Views)
Accepted by topic author mulhall
Same here but I notice that my share folder is the same as my older CWS files developed with CVI 8.5.1.
CVI Shared Dir = "/C/Program Files (x86)/National Instruments/Shared/CVI"
I looked more closely in that folder structure and found that:
C:\Program Files (x86)\National Instruments\Shared\Analysis
contained the nianlys.dll from CVI 8.5.1.    My new installation of 2012 did not overwrite this with a later copy.
This may be the first of many such instances where old versions conflict with new.    I may regret trying to keep the old version of CVI on this machine to support previous installations.
Thank you for leading me down the correct path!
Phil
(3,448 Views)
