06-10-2013 04:15 PM
The header file generated from the uir file has a duplicate macro definition. I deleted the file and rebuilt and got the same results:
"FMTSTCAL.h"(547,45) Redefinition of macro 'Menu1_Test_SEPARATOR'.
06-10-2013 05:49 PM
It seems you have added two separators to a menu with the same name.Try renaming the separators to obtain different names (e.g. SEP1, SEP2...)
06-10-2013 06:15 PM
Thank you. I inherited the .uir file (from 1992! LabWindows v 2). I'll take a closer look at. Thanks!
