09-06-2005 10:01 AM
09-07-2005 08:48 AM
09-07-2005 10:13 AM
The CVI XML functions are written on-top-of the Microsoft XML DOM parser (MSXML) using ActiveX. Based on ActiveX versioning rules, the CVI XML calls should end up going to the latest MSXML ActiveX components on your system. But if you are looking for some MSXML 4.0 related features to be added to the CVI XML functions, then that would require a rewrite of the CVI functions and changes in the API - if you have any particular feature in mind, please let NI know about this.
09-07-2005 11:21 AM
And as Mohan said, if you want specific functionality added to the CVI XML calls, you can make a product suggestion on the following site.
09-08-2005 05:28 AM
Thanks for the information.
The link http://forums.ni.com/ni/board/message?board.id=180&message.id=8406&requireLogin=False was why I assumed it was MSXML 2.0 only.
The current CVIXML API doesn't cater for stylesheets, so I've put in a suggestion for that.
On a separate point.
I want to insert a namespace xmlns declaration into my root element of an XML document. However, all children
are getting xmlns="" inserted in their elements.
( The problem is better described in the MSDN article at http://support.microsoft.com/default.aspx?scid=kb;en-us;828928 )
Is there any way of getting round this with the CVIXML libraries?
It seems to me that to get the root element I have to create a document, but I need to set this xmlns attribute before creating the document, (A bit of a catch-22 situation!)
Maybe I'm doing something wrong, but any advice would be appreciated!
Brian
09-08-2005 11:29 AM
09-09-2005 03:49 AM
11-13-2015 01:34 AM
Hi Mohan,
Could you please provide the header file as well? I looking for xml parser urgently but my current version does not have cvixml.fp at all. I tried program with MSXML4.0 but it was too difficult to me as a beginner. Appreciate if you can help me out.
Thank you very much.
MC
