I have a CVI5.5 project that I am trying to compile/link in MSVC++ 6.0. I am getting link errors in MSVC++ for some of the ANSI-C standard library functions: _GetErrno, _GetFloatMin, _setjmp, vscanf, vsscanf, among others. I've looked through the MSVC++ documentation and I can't find mention of these functions anywhere (i.e., they are not supported!?) My application makes use of the LoadExternalModule function, so I have created a .h and .obj file which lists all of the exposed functions in the CVI project (plus it means that I have included the \cvi\extlib\arefsym.c and refsym.c files in the MSVC project). The CVI documentation says that if using ANSI-C functions and compiling/link
ing in an external compiler, to use the external compiler's ANSI-C libraries (i.e., so do not include the \cvi\include\ansi\ in the MSVC search path) I've done all this and I get the above link errors. Any idea as to what is happening here? Would a possible remedy be to completely avoid using the MSVC ANSI-C libraries and just use the ones that come with CVI?
