LabWindows/CVI
Are some ANSI-C standard functions available in LW/CVI 5.5 not supported in MSVC++ 6.0?
I have a CVI5.5 project that I am trying to compile/link in MSVC++ 6.0. I am getting link errors in MSVC++ for some of the ANSI-C standard library functions: _GetErrno, _GetFloatMin, _setjmp, vscanf, vsscanf, among others. I've looked through the MSVC++ documentation and I can't find mention of these functions anywhere (i.e., they are not supported!?) My application makes use of the LoadExternalModule function, so I have created a .h and .obj file which lists all of the exposed functions in the CVI project (plus it means that I have included the \cvi\extlib\arefsym.c and refsym.c files in the MSVC project). The CVI documentation says that if using ANSI-C functions and compiling/link
ing in an external compiler, to use the external compiler's ANSI-C libraries (i.e., so do not include the \cvi\include\ansi\ in the MSVC search path) I've done all this and I get the above link errors. Any idea as to what is happening here? Would a possible remedy be to completely avoid using the MSVC ANSI-C libraries and just use the ones that come with CVI?
(2,624 Views)
Looks to me like you are using the CVI standard header files rather than the MSVC header files. Or you are trying to link a .obj compiled with CVI into an MSVC app. e.g. the 'errno' ANSI macro in CVI resolves to a call to _GetErrno(), whereas the MSVC one doesn't.
However, MSVC does not implement vscanf or vsscanf at all (they are not ANSI functions, according to my book).
HTH,
Martin
Martin
Certified CVI Developer
(2,624 Views)
