LabWindows/CVI
Are CVI 2013 SP2 UIR files different from earlier versions, e.g. 2013 SP1?
Accepted by Wolfgang
Hello Wolfgang,
Now I see what you are talking about. You are making changes in uir that normally shouldn't change the header file.
In 2013 SP2 there is indeed a change to the uir header file.
On the 3rd line before SP2 there used to be a comment like:
/* Copyright (c) National Instruments 2014. All Rights Reserved.          */
 This was removed in SP2.
So when you first save the *.uir in SP2 the UIR generated header file is re-written with this change.
Constantin.
Message 11 of 13
(2,212 Views)
ah, good, thanks! So the answer to my question is yes, 2013SP2 files are different Smiley Happy
Message 12 of 13
(2,210 Views)
Yes, the UI header files are changed.
Message 13 of 13
(2,207 Views)
