12-20-2016 10:05 AM
Critical updates for the LabWindows™/CVI™ 2015 SP1 Development Environment and the LabWindows/CVI 2015 SP1 Run-Time Engine have been released. Note: These are two separate patches.
You may obtain the update using NI Update Service or by using the associated download page on ni.com/downloads. You may find the list of issues fixed by the update in the LabWindows™/CVI™ 2015 SP1 Patch Details.
Trent Weaver
Automated Test Software PSE
12-20-2016 01:48 PM
Hi Trent
Can you clarify the following note:
The LabWindows/CVI 2015 SP1 f1 Patch is recommended for users of LabWindows/CVI 2015 SP1 who distribute applications for Windows XP.
How I can generate an XP installer? I don't see XP in the "Minimum operating system version" list in Advanced tab of "Edit Installer" dialog. May be using this trick?
12-20-2016 02:41 PM
Carlo,
Yes - the KB you pointed out is accurate for CVI distributions built after installing this patch. Since XP isn't officially supported in 2015 SP1, you cannot select it as a minimum OS version for distributions.
-Trent
12-21-2016 04:06 AM
Trent, is there a way to programmatically understand if the RTE has been patched or not? GetCVIVersion still returns 1501 and GetCVIVersionYear simply state 2015...
12-21-2016 05:20 AM
This has been suggested some time ago and the idea is even under review - so maybe in the future we will be able to find out easily (not having to use registry ...)
12-21-2016 05:49 AM - edited 12-21-2016 05:50 AM
Wolfgang, no need to use registry, only a function from Version.Lib.
beware: this is quick & dirty code, just tested only on my PC. It prints version info in the passed string.
int GetCVIRTEVersion(char *s) { char sFile[MAX_PATHNAME_LEN+1]; unsigned int iBufferSize,iDummy; char *pBuffer; VS_FIXEDFILEINFO* fixedVerInfoPtr; int iVer[4]; unsigned int len; // CVIRTE is obviously already loaded... GetModuleFileName(GetModuleHandle("CVIRTE"), sFile, MAX_PATHNAME_LEN + 1); // get size of version info (0 if no version info exists) iBufferSize = (unsigned int)GetFileVersionInfoSize(sFile, (LPDWORD)&iDummy); if (iBufferSize > 0) { pBuffer = malloc(iBufferSize); // get fixed file info (language independent) GetFileVersionInfo(sFile, 0, (unsigned long)iBufferSize, pBuffer); VerQueryValue (pBuffer, TEXT("\\"), (LPVOID*)&fixedVerInfoPtr, &len); // read version blocks iVer[0] = HiWord(fixedVerInfoPtr->dwFileVersionMS); iVer[1] = LoWord(fixedVerInfoPtr->dwFileVersionMS); iVer[2] = HiWord(fixedVerInfoPtr->dwFileVersionLS); iVer[3] = LoWord(fixedVerInfoPtr->dwFileVersionLS); sprintf(s,"%d.%d.%d.%d",iVer[0],iVer[1],iVer[2],iVer[3]); free(pBuffer); } return 0; }
03-14-2017 07:43 AM
I tried to install this patch on a PC with W7 Pro 64 bits but got an error that the patch is not compatible with my OS.
Is this normal? I couldn't find any explanation for which OS this pacht is compatible.
Bertrand
03-15-2017 11:20 AM
Both the LabWindows™/CVI™ 2015 SP1 f1 Patch and the LabWindows™/CVI™ Runtime 2015 SP1 f1 Patch should be compatible with Windows 7 based on the Operating Systems listed on the download pages linked. What is the error that you're getting exactly?
03-16-2017 02:51 AM
See attachment
03-16-2017 03:05 AM
I saw a similar error, in the past, when attempting to install a program in a XP machine that was not updated to the latest patches.
Is your Windows 7 fully updated, to SP1 mainly and with the following patches?
