Hello
So this only started happening when you tried using the newer activex client in CVI? If this is the case, you should try rebuilding the entire instrument file (if you havent already), just to make sure all the functions sync up with the new server object's methods and properties. If you are still having problems with it, I suggestion email a small example that would demonstrate the problem and the server itself by going to
this link, and generating a email request. Please add my name to the subject line, and I'll see if I can help you out with this
Bilal Durrani
NI
Bilal Durrani
NI
