"Hello, I'm using Labwindows/cvi 6.0 and I've a problem when I try to atach datagrid to Ado data control (both activeX) in UI panel editor. Is not possible to attach DataSource field from Datagrid to Ado, I can't access DataSource field. Why? Is not possible to use it at design time? I've tried to use programmatically but I have no idea how to use the function SetByReDataSource (from DataGrid), the third parameter is the control Ado. How can I pass it from the Ado ActiveX handle?
My knowledge on database programming is limmited, however it is possible that the "control ADO" parameter that you need to pass to the SetByReDataSource() function is a handle to the actuall database that you previously opened and get a reference to.
Another idea is to look for some code on the web for this; even if it is for Visual Basic or some other language it should be helpfull on understanding the programming of the controls.
