11-16-2013 08:31 AM
Windows 7 provides the possibility to maximize windows by moving the upper/lower window bar to the upper/lower screen border. This works even for CVI
If I have the environment option 'Hide windows when application is running' selected, after closing the application and returning to the source code window it turns out that CVI does not honor/remember the screen size, i.e. the CVI window size is not maximized any longer
If possible, I'd prefer to have it fixed
Workaround is to not to use an automatically maximized window... manually adjusted window sizes are remembered.
11-19-2013 12:02 PM
Hi Wolfgang,
I wasn't able to reproduce this, but I'm not sure that I'm doing the same exact thing that you described. Can you take a look at this video and let me know if it's different?
Luis
11-19-2013 12:24 PM
Hi Luis,
Thanks for your feedback, as always! I hope you don't expect me to produce a video
I am doing it in a slightly different way:
1. Move upper window frame to upper screen limit
2. Move lower window frame to task bar until the window frame 'flashes' and adjusts to full height
I do not maximize the window, only adjust its height
11-20-2013 04:23 PM
Ah, I see. You were referring to the edge-specific window maximization (maximized only horizontally, or only vertically).
You're right, CVI doesn't handle these maximization states well. For example, if you close the CVI ADE with the workspace window in this edge-maximized state, even though the window will appear to have the same size when you restart CVI, it no longer is aware that it's maximized and so it has lost its original, non-maximized dimensions. It no longer behaves like a maximized window.
The symptom you described is another manifestation of the same problem.
I've created CAR 437791 to track this.
Luis
11-21-2013 12:42 AM
Thanks Luis!
11-25-2013 09:09 AM - edited 11-25-2013 09:26 AM
In this thread I have learned a new Windows feature I wasn't aware of till now!
It's probably just one less out of that 10k and more I haven't even heard anything about...
Thank you both for your posts.
11-25-2013 09:19 AM
Yep, and after slowly adapting to the "new" Windows 7 world we will need to adapt to the very different Windows 8.x world, sooner or later... Life is full of challenges But let's celebrate that we have passed Windows 3.x
11-25-2013 09:27 AM
BTW, I was just curious about which event is received during this type of maximization (a bunch of EVENT_PANEL_SIZING and one EVENT_PANEL_SIZE, that is there's not a special event for this, which which seems correct to me) and found that sometimes I receive an event 54 which is not included in the list of available events up to CVI2012SP1. What's this?
11-25-2013 09:51 AM
#define EVENT_PANEL_RESTORE 54
I thought it did exist already in CVI2012...
11-25-2013 10:20 AM - edited 11-25-2013 10:20 AM
It does exist: the panel receives it even if it is not defined in userint.h and UILEventString function is not able to decode it.
Thanks for lettimg me know: I receive one restore event at program start, which sounds correct, and also one restore event for every sizing event which could be correct as well, depending on what you mean by "restore". Since I'm not the one that chases sizing events (when I have sizable windows I normally handle only size event) I can quietly ignore restore events as well
