I'm using CW3DGraphLib in Labwindows/CVI version 9.1.1 to create surface plots.
I have the following problem: after changing the min/max settings for any of the axes or applying autoScaleNow, the surface doesn't redraw to indicate the changes. If I use the Surface+Lines or Lines only surface style, then the lines do update but the surface doesn't.
Thank you.
