10-12-2015 04:30 PM
CHECK_MUX(Ag34980a_SetAttributeViBoolean(MuxSession_s, "slot1com1", AG34980A_ATTR_IS_CONFIGURATION_CHANNEL, VI_TRUE)); CHECK_MUX(Ag34980a_SetAttributeViBoolean(MuxSession_s, "slot2com1", AG34980A_ATTR_IS_CONFIGURATION_CHANNEL, VI_TRUE)); CHECK_MUX(Ag34980a_Connect(MuxSession_s,"1001","abus1")); CHECK_MUX(Ag34980a_Connect(MuxSession_s,"1008","abus1")); CHECK_MUX(Ag34980a_Connect(MuxSession_s,"2021","abus2")); CHECK_MUX(Ag34980a_Connect(MuxSession_s,"2028","abus2"));
I'm using the keysight IVI-C driver (I might just switch over to the class driver at this point). I'm using the above MUX. I want to make a 4 wire own measurement, but cannot use the built in measureFresistance function as I am only using one side of the two pole relays. Here is my setup above for the connecting the relays. My next question is how do I simply setup the DMM to make a 4 wire measurement now that everything is connected? I'm not sure why it isn't clear.
10-13-2015 05:27 PM
Did you mean to attach an image?
10-14-2015 06:32 AM
No but the code caption didn't show up?
10-15-2015 11:51 AM
Did the documentation for Keysight Device (34980a) provide adequate guidance? Unfortunately these drivers are not created by NI and are not officially supported. You may be more likely to find support in the Keysight Forum.
