We see the DAQmx -200279 error during extended runs of continuous acquisition. We can go for hours without seeing the issue. I have attached the main blocks of our data acquisiton module (daq_code.c).
Some observations / comments:
Debug build
We saw much improvement setting sleep policy to VAL_SLEEP_MORE
The nSamples value in callback when error occurred appeared to be a value of 8 (at least in CVI debugger). We had setup the callback to be called every 800 samples.
We do use remote desktop connections to view extended runs. Although, it does appear that the issue occurred at least once when RDP was not being used.
Source module for DAQmx acquisition is built into a DLL. The application and DLL share a thread safe queue.
Questions:
Is it advisable to override the default DAQmx buffer size?
Is it OK to assume that both DAQ1 and DAQ2 will have the same number of samples when Callback function is called? (since they are synchronized in initialization)
Is there a way to ignore the -200279 error and not lose the proper order of samples based on channels
Could the counter task have any impact on AI tasks?
- You can change the DAQmx buffer size according to your needs.
- It would depend on the device itself, synchronization assures you that they will begin at the same time, but data availability depends on the hardware.
- You could make an exception for the error by handling it.
Please check the following documents to make sure that you can prevent the error from happening:
