LabWindows/CVI User Group Documents
LabWindows/CVI Tip: Refreshing Standard I/O
The standard I/O window does not refresh when a program is suspended.
However, you can use the "Use console window for standard I/O when debugging" option to instead use the DOS console window which does refresh.
Alternatively, you can hit <Ctrl-R> to refresh any UI (including the standard I/O window) while you are suspended.
Did you find this tip useful? Rate this document or add a comment below.
If you give this a try, share your experience! Add a comment below.
Adri Kruger
LabVIEW Product Marketing
Contributors
