In CVI 2013 is option “Run -> Attach to Process…” and new is option “<< Running >> -> Detach from a process” during debugging, which is very good to debug TestStand sequence and CVI DLL, advantageous if I need to update CVI code and do not have to launch TestStand again and again after new CVI code is builded. Hovewer, to attach CVI DLL to a process is always necessary to do next steps: Run -> Attach to Process…, then select process from a list (seqedit.exe) and click OK. I would appreciate similar option as “Specify Executable to Debug…” or key shortcut to attach process directly to TestStand in one click or using simple key shortcut.
