LabWindows/CVI Idea Exchange
About LabWindows/CVI Idea Exchange
Do you have a feature idea for how to improve LabWindows/CVI? Submit and vote on ideas now!
  1. Browse by label or search in the LabWindows/CVI Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. You should submit a separate post for each idea. Watch as the community gives your idea kudos and adds their input.
  3. Give kudos to other ideas that you would like to see implemented!
  4. NI R&D will review ideas that have been submitted and update the status.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
Top Kudoed Authors
User Kudos Count
1
1
Put the X on the tab it goes with.
This X just closes out of the tab that is on top.
Pretty much every other program with tabs has the X on the tab you’re closing out of. The current placement makes me hesitate every time, because it feels like you’re X-ing out of the entire code-viewing pane, not just the single file you want to close.
It’s also not consistent with the rest of the environment.
For example, in the pane on the bottom in the screenshot above, “Threads” and “Wa tch” look like two tabs, but clicking the X in that pane causes the entire pane to disappear rather than just closing the tab that is on top.
13 Comments
The inconsistent behavior of the closing X is really annoying! And if I could dock the Build Errors to the left screen side like in Visual Studio (widescreen monitors!) it would be even better. Thanks.
/* Nothing past this point should fail if the code is working as intended */
Proven Zealot
I second this suggestion. At present I use Ctrl+W to close the active window
It's not necessarily relevant here, but TestStand has the same problem. The placement of the X creates ambiguity about what you're actually closing out of when you click on it:
Status changed to: Under Consideration
Jonathan N.
Knight of NI
Anyone who likes this idea should also kudo the same idea for the Test Stand product.
Put the X on the tab it goes with in the Sequence Editor
I would say get rid of the Confine/Release concept all together.  Just make this drag and drop.  And, make the Editor area and MDI (Multi Doc Interface) area.  Each tab with it's own "X" and "_" (minimize/expand) buttons.  (only the selected showing)
Nope. Do not like. At least I always know where the cross is (upper right) and that it will close what is currently open. Otherwise I have to visually search for which tab is active. If I want to do that I can always middle-click on it to close it.
First thing I do in Firefox (browser.tabs.closeButtons=3 in about :config. And other apps as well) is to put the closing control where it belongs, in the upper right.
I'm indifferent about this, except that IF the X is put on the tab it MUST always be visible. Having one that appears on mouse-over (like in Safari) is terrible design. A user can intend to activate that tab by clicking on it, only to find that they have closed it because the X materialized under their cursor an instant before they clicked. --Ian
Yes, plus putting the X on the tab allows you to close tabs you are not currently on without switching to them to close them.
Status changed to: In Development
Hi K_Joy,
Thank you for your post. We are moving forward with development of this feature. It should be included in the next available release of LabWindows/CVI.
Collin Draughon
LabWindows/CVI Product Manager
Collin D.
Software Product Manager
