LabWindows/CVI Idea Exchange
Wolfgang
Portable 'Projects' (Import/Export 'Project')
Status: New
usually I work on my projects on two different computers (home/work or development/lab). I would like to see a possibility to more easily move my project back and forth, say by providing two new menu commands
File / Import Project and File / Export Project
I imagine that the Export command generates a zip file consisting of all files required to build the executable (and a distribution) and also exports the editor preferences (probably without the window positions because different computers may have different screen resolutions) etc. The Import command then should load the *c., .cds, .cws, *.fp, *.h, *.prj and *.uir files, import the editor settings, adjust the library menu and load any instruments.
Thanks!
3 Comments
vix
Moving a project from a PC to a different one is a mess.
In the past I discussed with NI guys about this issue, without finding a satisfying solution.
The .cws file, in particular, is a real problem (by design it should be specific to a development PC, but in the fact it isn't) and NI suggested me to delete it before moving the files to a different PC.
I've been really waiting for an effective way to move projects, but I'm afraid is not so easy to have it soon
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
gdargaud
I think a better solution to the original question is to use version control like SVN. If one system doesn't have online access to the repository (unlikely those days), you can always use SVN to generate a patch for the modifications done since the morning.
Wolfgang
Trusted Enthusiast
For me a good solution is a simple solution. Installing an online repository just to be able to work at home seems a bit overdone
