NI Home
Cart Cart | Help
You are here:
Announcements
The NI Idea Exchange is a product feedback forum where NI R&D and users work together to submit ideas, collaborate on their development, and vote for the ones they like best. View all of the NI Idea Exchanges to post an idea or add your opinion on an existing one today!
Al.B
Modify CVI XML Library To Allow XML To Be Loaded From a String
Status: Under Consideration
by Active Participant Al.B on ‎10-12-2010 01:07 PM
Currently, it is only possible to load XML for parsing from an xml file.  In order to load xml data from a string, it is necessary to either write to a temporary file, or use the MSXML library directly.  It would be fairly simple to modify the CVIXMLLoadDocument() Function (or create a new function) which uses the MSXML IXMLDOMDocumentloadXML() function, which allows loading XML directly from a string.
Adding this code to the current function after the IXMLDOMDocumentload() function would improve the CVIXMLLoadDocument() function so that it tries opening the input string as direct XML if it is not a path (Replaces line 167):
__caErrChk(MSXML_IXMLDOMDocumentload(xmlHdl, NULL, variantPath, &success));
	if(!success) //if loading as a path fails, try reading as direct XML code
        __caErrChk(MSXML_IXMLDOMDocumentloadXML(xmlHdl, NULL, fullPath, &success));
Comments
by Member silmaril on ‎10-26-2010 02:01 AM
Good idea! Kudos!
But I strongly recommend creating a new function instead of messing up the existing ones by adding unintuitive functionality.
by Active Participant JonathanN on ‎10-23-2012 02:33 PM
Status changed to: Under Consideration
About LabWindows/CVI Idea Exchange
Do you have a feature idea for how to improve LabWindows/CVI? Submit and vote on ideas now!
  1. Browse by label or search in the LabWindows/CVI Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. You should submit a separate post for each idea. Watch as the community gives your idea kudos and adds their input.
  3. Give kudos to other ideas that you would like to see implemented!
  4. NI R&D will review ideas that have been submitted and update the status.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
Idea Statuses
Top Kudoed Authors
User Kudos Count
6
4
3
2
2
