LabWindows/CVI Idea Exchange
40tude
Make sure all function panel use the right kind of controls
Status: New
Make sure ALL the function panels use the right controls
For example in the CVIDynamicMemoryInfo function panel below, the "Options" parameter should not use the String Ctrl.
Instead it would be "safer" to use a list box, a ring or whatever make sense to display the two available choices :  DYNAMIC_MEMORY_SHOW_ALLOCATED_MEMORY or DYNAMIC_MEMORY_SHOW_ALLOCATED_MEMORY_SUMMARY
This would help to reduce the typo errors etc.
Regards, 40tude
Regards, Philippe proud to be using LabWindows since version 1.2
1 Comment
Wolfgang
Trusted Enthusiast
Supported - although your suggestion might also be considered as a bug report Smiley Wink
