LabWindows/CVI Idea Exchange
About LabWindows/CVI Idea Exchange
Do you have a feature idea for how to improve LabWindows/CVI? Submit and vote on ideas now!
  1. Browse by label or search in the LabWindows/CVI Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. You should submit a separate post for each idea. Watch as the community gives your idea kudos and adds their input.
  3. Give kudos to other ideas that you would like to see implemented!
  4. NI R&D will review ideas that have been submitted and update the status.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
Top Kudoed Authors
User Kudos Count
1
1
Library to handle JSON data
In the last few years JSON came out as new format for data objects consisting of attribute-value pairs, largely replacing XML.
LabVIEW has functions to handle JSON data, and LabVIEW Community has been developing a JSON Toolkit.
In the CVI board of the forum this is the only result for a "JSON" search (at the present).
I suggest to integrate into CVI a JSON library (for example JANNSON).
I think this is better than develop a proprietary library.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
