LabWindows/CVI Idea Exchange
Wolfgang
Improved error reporting
Status: New
When building a project consisting of many files it would be much more convenient if the Build Output would jump to the line with the first file showing an error (or, if no error occurred, to the first warning).
Right now, if there is a build error I have to scroll through the (possibly long) list of files to see which file produced the error; only then I can click on the error message to have the IDE highlight the problematic line.
3 Comments
CVI-User
Great idea! I second that!
(5 years old, still under consideration: http://forums.ni.com/t5/LabWindows-CVI-Idea-Exchange/Build-Output-Prefer-Errors-over-Warnings/idi-p/... )
/* Nothing past this point should fail if the code is working as intended */
Wolfgang
Trusted Enthusiast
Thanks Smiley Happy
'Under Consideration' is not so bad... much better than a 'New' idea of the same age Smiley Wink
scottrod
Previous versions did this. Can't believe it's not in CVI 2013. Grrr.
