LabWindows/CVI Idea Exchange
RobertoBozzolo
Enable "View control callback" when multiple controls with the same callback are selected
Status: New
Right now if multiple controls are selected you cannot jump to the code with "View control callback" menu option or Ctrl+B accelerator even if they have the same callback. It could be handy to be permitted to go to source if selected controls have the same callback.
Consider this scenario:
On a panel you create two buttons, select both of them and edit their properties assigning a (unique) callback to both. Next with both controls selected you generate the callback using "Generate Control Callback" or Ctrl+G. Now you would like to go and code something in the callback but you're not allowed to: you need multiple clicks to go to source: one click anywhere on the panel to deselect controls, one to select one of the buttons and finally the right click or accelerator key. Not very handy...
