When using the UI functions, a neat feature is the ability to pull up a dialog of valid control IDs when specifying the control:
clicking the elipses displays this dialog showing all valid control IDs:
If you are using the function panel however, you cannot access this dialog and you are on your own for figuring out the correct control ID:
I think we should add this functionality in the function panel for any function that has a control ID parameter.
Al B.
Staff Software Engineer - TestStand
CTA/CLD
