LabWindows/CVI Idea Exchange
About LabWindows/CVI Idea Exchange
Do you have a feature idea for how to improve LabWindows/CVI? Submit and vote on ideas now!
  1. Browse by label or search in the LabWindows/CVI Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. You should submit a separate post for each idea. Watch as the community gives your idea kudos and adds their input.
  3. Give kudos to other ideas that you would like to see implemented!
  4. NI R&D will review ideas that have been submitted and update the status.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
Top Kudoed Authors
User Kudos Count
1
CVI Applications running on the MAC OS, IPad, IPhone and Android Devices
Is NI road map going to allow applications that are developed with CVI for Windows to run also on the Apple MAC OS as well as run on IPhone and Android Devices? The current alternative to develop the applications for the Apple MAC OS is on X-Code IDE where the code with Objective C (and Objective C++). The code that is developed with CVI cannot be ported over to the MAC OS because Objective C is not based on the ANSI C Standard. X-Code IDE is a powerful but also a clumsy IDE and can be unforgiving. NI also provides the drivers for most its hardware for the MAC. In my opinion the CVI IDE has a much better IDE than X-Code and CVI is more intuitive to use from a development perspective.  Since there is open source CLang Compiler for the MAC why can't NI import the CLang Compiler to work with the MAC and IPhone? Both Windows and MAC use the same Intel Microprocessor. Intel also has a compiler for the MAC OS that is separate from the X-Code IDE.
To develop the applications for Android devices requires the Eclipse IDE. Can CVI be adapted to develop software with the Eclipse IDE like an add-on?
