as discussed in this thread changing the map mode of a graph axis from linear to logarithmic scaling may perform sub-optimal if the graph shows plots containing zero or negative data values. Fortunately, there is a workaround.
The suggestion presented here is to make this workaround unnecessary... Ideally, the graph should take care by itself if plots need to be updated, i.e. changing the attributes ATTR_XMAP_MODE and ATTR_YMAP_MODE from VAL_LINEAR to VAL_LOG should result in updated plots.
