I'd like to see better documentation online.
Currently, documentation seems to be spread over different areas: online, in sample code included with the development environment, in a downloadable help file, etc. What online documentation there is is incomplete - for instance, if I'm looking at the function reFFT (just an example, I know it's obsolete), the online help gives me the parameters and what they are but they don't tell me acceptable values, e.g. what is the largest/smallest value I can use for numberOfElements: 1 - 9e99999? Another case was with the NIscope driver NISCOPE_ATTR_INPUT_CLOCK_SOURCE. When I looked at the documentation (downloaded zip file filled with CHM files) there was a list of defined values but no desciption of what they were or were not for. Example: NISCOPE_VAL_NO_SOURCE ("VAL_NO_SOURCE")...I *assume* NO SOURCE is equivalent to Intenal but should I really have to guess when looking at documentation? For that matter, why does this information only appear to be available via downloadable file?
In another case with NISCOPE I found that the niScope_ConfigureHorizontalTiming expects a certain clock frequency (10 MHz) if you're using an external clock, but if you are using a clock frequency at exactly what you're asking for you have to set the attributes directly. I messed with this for a while before calling the help desk. The person at the other end was able to tell me how to fix my problem but he could not find documentation online (accessable by me) where this information could be located. It seems to me that the number of help calls could be drastically reduced if sufficient help were available online. Finding information on error codes is similarly lacking.
I also have a problem with referencing "installed" sample code in lieu of a online programmer's manual. I don't always run on my development machine. So I'm on my target system (that does not have the development environment installed) and I want to look something up...it's very frustrating to find all help on a particular subject referring to my development machine.
