LabWindows/CVI Idea Exchange
About LabWindows/CVI Idea Exchange
Do you have a feature idea for how to improve LabWindows/CVI? Submit and vote on ideas now!
  1. Browse by label or search in the LabWindows/CVI Idea Exchange to see if your idea has previously been submitted. If your idea exists, be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click New Idea to submit a product idea. You should submit a separate post for each idea. Watch as the community gives your idea kudos and adds their input.
  3. Give kudos to other ideas that you would like to see implemented!
  4. NI R&D will review ideas that have been submitted and update the status.
Note: the LabWindows/CVI Idea Exchange is not the appropriate forum to submit technical support questions.
The LabWindows/CVI R&D team is committed to reviewing every idea submitted via the LabWindows/CVI Idea Exchange. However, we cannot guarantee the implementation of any LabWindows/CVI Idea Exchange submission.
Ability to pass NULL to many library functions
There are many library functions that return several parameters. Many of which you may not care about. Some functions allow you to pass NULL to ignore some returned parameters, but many do not.
For instance:
LinFit (X, Y, NbP, NULL, NULL, &Intercept, &Err);
if you are only interested in the Intercept and error values, will crash on run with a "Null pointer argument to library function" fatal error.
The way it's currently written , you have to (correctly) declare plenty of dummy arguments for your calls.
1 Comment
Member TheNIDragon
Status changed to: Under Consideration
Hi @gdargaud,
Thank you for your post. The behavior you are referencing is something we have taken into consideration, especially with the implementation of any new libraries that the CVI team develops. Because CVI is a client of many of the libraries from our internal driver teams and third party instrument driver/library developers, it will be difficult to assure that every function you use in CVI supports this functionality though we will do our best to make this functionality as universal as possible in the near future. Thanks again!
