yyyy
how to open a PDF file from the labview?
(2,317 Views)
You forgot to put your student ID in your post. The other students who asked the exact same question in the last couple of days at least remembered to do that. Your subject line is absolutely worthless.
(2,314 Views)
Hey fang55,
Make sure that you add a sensible subject to your messages from next time and try to search the forum before posting a question. I think this must be already answered by someone in this forum.
Its not very clear from your question what you are intending to do. If you just want to open a pdf file from labVIEW, you can use the vi which comes packed with the LabVIEW vi library (C:\Program Files (x86)\National Instruments\LabVIEW 2010\vi.lib\Platform\browser.llb\Open Acrobat Document.vi).
Or if you want to load it on the front panel and display the pdf, you may need to use an ActiveX control and do it. There are plenty of example of it in the forum which you can search for.
regards,
NitzZ
(Give Kudos To Good Answers, Mark it as a Solution If your Problem was Solved :smileywink:)
(2,309 Views)
This question has been answered many times. If you typed a meaningful title to your post you would see those answers in the automated search.
(2,276 Views)
