05-15-2013 09:26 AM
the example is based on VISA communication using Write and Read VIs. Have a look at this NI-VISA Overview
05-15-2013 09:30 AM
The example VI sets the display configuration and reads measure value for the WT3000.
This VI is an example of how to use the WT3000 subVIs programmatically. This VI sets the display and Preset item, reads the measure value.
see the VI and SubVIs documentations
05-15-2013 10:18 AM
you mean application example2.vi
05-15-2013 11:30 AM
ok ok got it thanks
05-16-2013 02:55 AM
yes example2.vi
It is a good example 🙂
05-16-2013 10:16 AM
hi!
did you get some data from your yokogawa wt3000?
05-17-2013 03:22 AM
I'm right now not working with yokogawa wt3000 but the example should work
05-17-2013 10:28 AM
i have an other question.
i want to read in labview the motor efficiency.
i found out that there are two VIs (Config Efficiency Udef.vi and Config Efficiency Eta.vi)
which one do i need?
Thank you for your help in advance
05-22-2013 04:38 AM
where did you find the two VIs?
05-22-2013 11:44 AM
there are by:
Instruments-IO--->Instrument Drivers--->YKWT3000 Digital Power Meter--->Configure
