xy graph cutting data
It did seem to fix my xy problem..my only worry is this offset....
Message 31 of 36
(1,170 Views)
Hey there,
It's possible that your 9215 is somehow not properly calibrated, which would explain the offset and why it appears correct when read by another source. Do you by any chance have another 9215 or some other analog input module to try the reading on? Have you tried other channels on this same 9215?
Eden K
Message 32 of 36
(1,132 Views)
It appears correct when read by a O-scope II, which I assume has an function built in to correct the offset. I did this in my vi and now the signal looks good. I don't have any other measurement devices to read the pk2pk.
Message 33 of 36
(1,116 Views)
Do you mean that you've now properly incorporated a solution to your offset in LabVIEW?
Eden K
Message 34 of 36
(1,085 Views)
That's correct!
Message 35 of 36
(1,076 Views)
Glad to hear!
Eden K
Message 36 of 36
(1,060 Views)
