xbee,labview,arduino interface
hello,
i nee to control a robot wirelessly using labview so i bought two xbee pro s2 modules with one arduino uno and one xbee shield..the problem is that i do not have the board which connect the xbee to the pc and it is not available in my country and i am running out of time so i cannot get it from another country...so if i bring another arduino with another xbee shield can i achieve that? and how?
thank you
(2,805 Views)
Arduino has many versions. Read their details for your requirement
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(2,772 Views)
Here is some link
http://arduino.cc/en/Main/ArduinoXbeeShield
http://arduino.cc/en/Guide/ArduinoXbeeShield
--Ranjeet
(2,769 Views)
the problem has changed now ...i fixed the baudrate for both xbee and in the labviewinterface.h file,also in the vi ..and still i cannot control wirelessly the arduino ...N.B: when i open the xctu software and write in the terminal window the DO led in one xbee shield and the DI led in the other xbee shield start blinking ..i think this means that the two xbees are connected (i am not sure).
(2,738 Views)
I have a question.
I have a program with serial VISA.
I bought the Xbee explorer USB and have a project that works well with Arduino. When I Serial Monitor, Xbee USB explorer automatically opens the Serial COM port lights and lamps Rx and Tx.
When you step into the LABVIEW the door does not open automatically.
Help me please it is urgent!
Thank you to all!
Philip
(2,551 Views)
