07-16-2014 11:22 AM
I am not getting the right graph.
Solved! Go to Solution.
07-16-2014 11:38 AM
07-16-2014 11:45 AM
well i am just trying to read my data i imported into a TDMS file. Here are the subvis sorry.
07-16-2014 12:11 PM
here is the tdms file
07-16-2014 09:04 PM
07-17-2014 01:14 PM
The graph is suppose to show the data that is in the tdms file but instead it gives me a really large amplitude that is wrong. the waveform is not being shown correctly and the number on the x axis should be in the lower 4000's.
07-17-2014 03:43 PM
The TDMS file is correct as I was able to tell by looking at it with the TDMS viewer VI.
The problem was the reader. I have no idea what you were doing but the attached is all you need.
Mike...
07-17-2014 05:49 PM - edited 07-17-2014 05:57 PM
I knew how to do that but I want it to work with this program where 4060 would be the number of ms on the x-axis and of course the amplitude on the y-axis. I want the read data to be converted into an array so i can display it on this graph and potentially take the derivative of the waveform.
07-17-2014 08:48 PM
07-18-2014 03:08 PM - edited 07-18-2014 03:12 PM
Now i get the wrong data at the end of display one electrode.
