03-24-2009 06:58 AM
Hi again,
I hope to see you, if you will be there...
Anyway, do you know what is 'Numeric Text' ?
in the Vi attached there is numeric text that is handled as text,
and if I change the handling (as in the picture) to numeric text, then there is an error.
So what is exactly 'Numeric Text' ?
Amitai Abramson.
03-24-2009 07:21 AM
Numeric Text is the text you find inside a numeric control. You can't create it yourself.
03-24-2009 07:54 AM
I am not sure that you are right, (even though I am 'YOTER TZA'EER)
This 'numeric text' is a part of the 'Decoration text' .
What I want, is to control programmatically the Decorations including free text like in the VI I have attached.
the problem is that I can't find an conventional way to diffrentiate between them in the Block Diagram,
and I thought maybe Numeric text has something to do with it... because I haven't understand what is exactly 'Numeric Text' (as a decotation).
I asked earlier the NI support and they said they get back to me with an answer.
Amitai Abramson
03-24-2009 08:01 AM
Amitai Abramson wrote:Hi,
Amitai Abramson
Without looking at your image my reply would have been the same as tst's but after looking at your image
...you got me wondering "what type of LV object is "NumericText" and I falied to find anything (bmp, decoration, line, text, gif, etc) that would return that class name.
So I am left wondering
What type of object is of class "NumericText" ?
At this point I uspect it may be an artifact from an old version of labVIEW but I am only guessing now.
Ben
03-24-2009 08:48 AM
I started a new thread here for the Q about NumericText.
Ben
03-24-2009 09:02 AM
Hi Ben, tst, (and everyone else)
Thank you for your help,
Do you know a way to differentiate between decorations in the block diagram ?
I can get their references in Array by choosing the Pane property 'Decorations[ ]' or 'All Objects[ ]' ,
but they are not labeled or with description.
I can set something different in their properties that do exist, and the user will not notice, (like a very slight change in the color of the text or decoration...)
but there must be a different way.
Amitai Abramson.
03-24-2009 09:04 AM
Amitai Abramson wrote:Hi Ben, tst, (and everyone else)
Amitai Abramson.
No. I think they are in the same order they were dropped on the FP but aside from that, ther is no way to ID them.
Ben
03-24-2009 09:25 AM
It is the class I refered to (as Saverio also pointed out in the other thread). The reason it's under Decoration is that it inherits from the Text class, which inherits from Decoration.
As for identifying a decoration, if you have 8.6, you can use the VIs in <vi.lib>\UserTags to set a persistent tag which will serve as the decoration's name, but I would advise to simply not use a decoration. If you want not to see the border of a control or an indicator, you can start with one from the classic palette, which you can then color transparent.
03-24-2009 09:44 AM
I have LV 8.2.1...
Anyway, I am building a simulator of something with several pages that the user will browse and fill in data where needed.
there is also some permanent data, of strings , so I want to avoid a large number of variables and make this a simple constant text (decoration).
and when the user will move from one page to the other, only the relevant ones will be visible.
I don't know if that is the best way to do it...
I will probably use the possibility of changing slightly the color so the user won't notice it
in order to distinguish one from another - you can see my try in the VI I have attached.
It saves me around 300 variables of strings, do you think it is necessary at all ?
thanks,
Amitai Abramson
03-24-2009 10:37 AM
I checked in which method, if I have a lot of items the application is more faster.
and I found out that it is faster with the variables and not with the decorations.
You can see it in the VIs attached one for each method.
(I must say that the VI act strange because when the Items "disappear" and I change the Boolean - 'Visible' again thy reappear reversely)
Amitai Abramson
