write to OPEN Excel file
How can I write to a generic Excel worksheet that is already open?
I want to be able to fill some cells in the Excel worksheet and do a save-as.
All the examples I have seen involve using ActiveX to start up Excel, open the file, select a worksheet, write to worksheet, save file, close file, and exit Excel.
A search showed a link to a message in the old forum.
(3,911 Views)
Are you trying to write to any open sheet or a specific one?  The specific one may be harder because you would need to get a reference to it.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,896 Views)
Right now the test process is semi-automated at best. There is an Excel worksheet that is open and test data
gathered are entered manually by hand then Save-As is done for each serial number. The manual entry
is error-prone, so I am hoping to eliminate that problem.
After some trial-and-error using the examples on ni.com as starting point, I am able to write to the open worksheet. 🙂
(3,890 Views)
Good Luck
Matthew Fitzsimons
(3,888 Views)
To nyc, you said you had it work. Would you please show me how to write data into specific cell of the excel sheet?
(3,559 Views)
KPRO,
There are several LabVIEW examples on this NI website for writing to Excel.
This is just one of them:  http://zone.ni.com/devzone/cda/epd/p/id/4523
Message Edited by nyc on 03-15-2008 10:06 AM
(3,539 Views)
Hi nyc,
Thank you very much for your help. Now I can read & write from/to excel via LV
(3,511 Views)
