05-20-2016 11:56 AM - last edited on 05-20-2016 12:19 PM by altenbach
@altenbach wrote:
@Artem.SPb wrote:
When you use "insert into array" each iteration you waste memory and time
It's not with every iteration. Also "built array" does the same thing so there is no difference.
do you mean that this 2 ways has no difference?
I see that 2nd twice faster
05-20-2016 12:20 PM
Artem.SPb wrote: do you mean that this 2 ways has no difference?
You cannot compare these two, because they are completely different. There will be a difference.
(I also thougth we are comparing "insert into array" with "built array", not some random other code.)
Since you chose to use a while loop instead of a FOR loop, the final array size is typically not know to the compiler, while in the lower part the final size is fully determined.
For the upper code, you would substitute a FOR loop autoindexing at the output. No shift register even needed.
05-20-2016 12:38 PM - edited 05-20-2016 12:42 PM
As said already, you are comparing apples and oranges because your left code only creates 3 columns while the right code create four columns.
You are also reading a control inside the first frame, an operation that you should not incude in the timing.
Here are two examples comparing apples and apples. Now the left side is even slightly faster.
If we need to include conditional appending as in the original problem, none of the two code fragments are appropriate anyway.
05-20-2016 12:48 PM
@altenbach wrote:
Artem.SPb wrote: do you mean that this 2 ways has no difference?You cannot compare these two, because they are completely different. There will be a difference.
You are right, for loop is better, but look at original code, Pavel_47 uses case in loop, so compiler don't knows array size. This is reason why I use while loop in my test.
I mean that build array at one step is better than build it in case-structure step by step.
05-20-2016 12:56 PM - edited 05-20-2016 01:05 PM
@Pavel_47 wrote:How to save column_0 in integer format, other columns - in floating point ?
You might not even need the 2D array, you could just stream the data to the file directly. Now you are guaranteed not to run out of memory (e.g. if you keep the code running while you go on vacation :o).
(If you also want to keep the 2D array, there are also better ways....)
05-20-2016 12:59 PM
If you don't know the array size, you cannot use the right code. So what's your point?
05-20-2016 03:27 PM
@altenbach wrote:
@Artem.SPb wrote:
You are right, for loop is better, but look at original code, Pavel_47 uses case in loop, so compiler don't knows array size. This is reason why I use while loop in my test.I mean that build array at one step is better than build it in case-structure step by step.
You want to fight about or offer the best option to Pavel?
I wrote, it is better to create an array at once, rather than a step-by-step using the case structure. Where is the error in my words?
05-20-2016 04:16 PM - edited 05-20-2016 04:25 PM
No fight, just wondering what you are trying to say....
In your "solution" you are building the 2D array one row at a time. I thought you were trying to improve on that in a later post, but you were talking about building the rows. The rows are so short that the preemptive over-allocation by the compiler will probably take care of things without needing memory reallocations, so it's not such a big deal.
(Autoindexing at the right loop boundary would be equivalent to your building of the 2D array, just simpler code!)
In contrast, my suggested solution does not even built an array. Hard to beat that 😄
If we would know the final array size beforehand, other good solutions will be possible. Growing arrays without size limit is never a good idea because of memory issues. I am sure it would take much longer to run out of disk space. Arrays need to be contiguous in memory, while files on disk can be fragmented.
