write formatted 2D data into a file
Here is emulation of an extract of my testbed (where data should be saved into a file for postprocessing).
Here are keypoints:
  • while running, the data are accumulated in a 2D array, where column_0 - the iteration number (integer value), column_1 ... column_3 - measured data (float values)
  • on button STOP click this array is saved into a file
The problem I've met in this example - the data in all columns are saved in floating point format (please, see the screenshot below)
How to save column_0 in integer format, other columns - in floating point ?
Message 1 of 18
(4,084 Views)
You can't store in one array different data type (see red dot mean type cast). So you can form 2 arrays or before writing split array and convert dbl to int.
Also, why you use event-structure out of loop? Your code wil work without it.
Message 2 of 18
(4,071 Views)
Indeed event struct  it's useless.
Concerning split arrays I didn't properly understand what you mean.
If I split 2 arrays and convert column_0 to integer, then how to proceed further ?
In the example below I tried to format splitted arrays into strings, but unfortunately write block doesn't support strings
Message 3 of 18
(4,058 Views)
Use "built array" instead of "concatenate string". This created a 2D array. transpose if desired. the file tool accepts 2D array of strings.
(A file is just a long 1D string, so to get better control, just format it all in memory, delimiters and all, and then write it to a plain text file.)
Message 4 of 18
(4,050 Views)
Even more simple - without FOR loop ... but still 1st column is formatted as float.
Message 5 of 18
(4,049 Views)
Accepted by topic author Pavel_47
When you use "insert into array" each iteration you waste memory and time
Message 6 of 18
(4,041 Views)
Build doesn't work (if I correctly understood your suggestion)
Message 7 of 18
(4,035 Views)
 Well, yes, it gets rid of the broken wire. 😄 I haven't studied what you really want. As I said, do all the formatting in memory to have full control, then just write a single plain string to a file. No need for fancy highlevel IO.
Message 8 of 18
(4,025 Views)
Artem.SPb a écrit :
I think this way to form array and string better.
Ok, thanks.
Message 9 of 18
(4,025 Views)
It's not with every iteration. Also "built array" does the same thing so there is no difference.
Message 10 of 18
(4,000 Views)
