11-08-2010 05:55 AM
11-08-2010 06:20 AM
Hi Mechen,
I am not sure what you want in the Y value of your array exactly. But just check the vi which i have attached. even if its not what you are looking for you can at least make use of the shift register concept for your vi in such a manner.
let me know whether this helps or not..
Nitz...
11-08-2010 07:29 AM
Hi Nitz,
Thank you again. It is ok but there is an unintended consequence. This is that the previous y data slip down at each loop iteration and the new value is always written in the first row of the secon column. What y data is that:
I traverse my probe to 0.977 m in the pipe cross-section and fix probe at this point . and then run and pause immediately the vi and it counts 10000. then the average value is calculated by means of "Amplitude and Level Measurements.vi". This value must be written near to 0.977 in 2d array. I change the probe location to 0.955 m and then again I click the pause button twice and it runs couting 10000 and then the vi waits and the average value is now written near to 0.955 and so on. So I will obtain y values (which are average velocities at each cross-sectional point) corresponding to each related probe position and find the y=f(x). So, could you please help me with this respect? thanks again.
11-08-2010 10:41 PM
Hi Mechen,
I guess I understood your problem this time. I am attaching your vi with a few changes. Have a look. I think this is what you needed.
Nitz...
( i hope at least this will earn me a kudo:) )
11-09-2010 01:44 AM
Hi Nitz,
thank you very much for your reply. Unfortunately, I could not open the vi you submitted. It is newer version. I have 2009 version. Could you please send it again? I have forgotten to say that the second row of the first column must be always constant zero. Because, the velocity on the wall denoted as "1 m" is zero. So the 2D array must be like this;
1 0
0.977 average value of the first loop iteration
0.955 average value of the second loop iteration
0.917 average value of the third loop iteration
0.88 average value of the fourth loop iteration
........ ....................................................... and so on......
mechen
11-09-2010 01:48 AM
Hi Nitz,
I'm sorry that I have a mistake. Previously, I have said that the second row of the first column must be always constant zero. This is wrong. The second column of the first row will be always constant zero.
11-09-2010 01:59 AM
Hi mechen,
after looking at your VI again I saw you already used a counter for your measurements... Why not use it for replacing values in the data array?
I also made a "true" 2D array constant from your initial array constant by adding an empty 2nd column. See attachment in LV2009.
11-09-2010 02:11 AM
Hi ,
I am attaching the vi in older version. Check it. The part in which the first row 1 and 0 is not done in this vi. Just check the rest of the things if its what you need or not.. if not, then threre's no point in my breaking head in bring the first row 1 and 0 🙂
Nitz
11-09-2010 02:23 AM
Hey hi,
I think i got what you are looking for... Its here...
Nitz
11-09-2010 02:54 AM
Hi Nitz and GerdW,
Thanks a lot for your replies and solutions. It is now ok!!! Thanks a lot...
