07-24-2015 07:34 AM
I know I should know this, but I don't.
In my code, wires from cotrols to case frames, Loop frames or any frames are sometimes have a different appearance than inside the frame. The wire seems to have a very thin wire wrapped around it...
If amyone knows why plese, tell me! See the attached exmple.
Solved! Go to Solution.
07-24-2015 07:36 AM - edited 07-24-2015 07:38 AM
Hi magyar,
this is very basic LabVIEW knowledge: wires show their datatype by color and thickness. The thicker the wire, the more dimensions of the array.
And another very basic LabVIEW knowledge: all this is easily found by reading what the context help window tells you about the wire(s)…
And even more very basic LabVIEW knowledge: the appearance of a tunnel at those structure borders tells you about it's behaviour!
When you don't remember those 3 very basic things you should (re)take the free online LabVIEW beginner resources offered by NI on their website! 😄
07-24-2015 07:43 AM
Thanks for the fast reply. What you wrote I do know. But that is not wat i was asking. Please look at the attached image.
On the left the boolean is a straight lile with a sinusoid superimposed on it. On the right, It is just a straight line.
Why?
07-24-2015 07:44 AM
forgot the image..
07-24-2015 07:45 AM - edited 07-24-2015 07:46 AM
That "shadow" (or sine) around the wire indicates constant folding. You can switch the display of constant folding on or off in the options.
07-24-2015 07:50 AM
Thanks!
I recently, for the very first time, I turned on constant folding.
07-24-2015 07:55 AM
07-24-2015 08:05 AM
GerdW,
You are right.
I used the Windows Snipping Tool and by default it wants to save snip as jpg.
Thank you for your time.
