02-28-2016 07:07 PM
Bill, Mike, OP that device is a 6356 ! RSE is not an option it only supports differential AI DAQmx will probably throw an error. Connect the gnd to pin 3 an pin 5 the AI signal to pin 4 the AO to pin 16 AI and AO gnds are internally connected.
02-28-2016 07:15 PM
02-28-2016 07:47 PM
@JÞB wrote:Bill, Mike, OP that device is a 6356 ! RSE is not an option it only supports differential AI DAQmx will probably throw an error. Connect the gnd to pin 3 an pin 5 the AI signal to pin 4 the AO to pin 16 AI and AO gnds are internally connected.
That's good to know. I didn't look at any details on the 6356. I would've assumed all DAQ devices had a single ended mode, and since that is how it appeared to be wired.
02-28-2016 08:09 PM
Once I saw AI1- not AI9 on the label I thought I'd better check the spec.
03-01-2016 08:45 AM
03-01-2016 11:24 AM
@choonkok wrote:
Hello. That's mean the sensor GND connect to pin 3 and 5. The sensor out will connect to pin 4. How about the sensor +v connect to?
That connection is fine as is
